Here are some parts that are lying around in the garage that i want gone:
S13/r32 lower control arms. can get pics if needed: $150
NRG Quick Tilt, will need a short boss kit to fit. Great for anti-theft as the included lock covers steering wheel nuts: $160
post-74083-0-72041600-1385629371_thumb.jpgpost-74083-0-18227600-1385629378_thumb.jpgpost-74083-0-64876600-1385629384_thumb.jpgpost-74083-0-84201500-1385629389_thumb.jpgpost-74083-0-37951700-1385629396_thumb.jpgpost-74083-0-15464600-1385629404_thumb.jpg
R33/RB25 std turbo + manifold, 80xxx km, never had any troubles, upgraded to 3076. Everyone knows what they look like, can get pics if needed: $250
R33/RB25 advance mild steel 3” dump to cat to suit standard turbo with screamer pipe: $150
post-74083-0-97967200-1385629533_thumb.jpgpost-74083-0-73817100-1385629539_thumb.jpgpost-74083-0-00223500-1385629547_thumb.jpg
Superspark coilpacks, good condition, holding 300rwkw fine, however got a good price on Yukon coilpacks so will be swapping them over soon. $200
Excedy cushion button clutch (pink) to suit rb (push style) upgraded to giken twin and its been sitting around for too long. Little rusty but works fine, great clutch for feel and bite. $250
Located in Launceston Tasmania, can post Aus wide.
Contact me on: 0407 323 643
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
