See this turbo housing ? This is the exhaust side
See the little circular flap and actuator arm - this and example of an internal or integral wastegate - In other words, it's integrated into the exhaust housing
Here's another pic of a housing with an internal gate
Internally gated turbo's require an actuator to open the gate:
This next pic is an example of a turbo with an external gate
The wastegate is mounted on the exhaust manifold.
Here's another
The actuator is built into the external gate.
A wastegated turbocharger includes an integral device to limit turbo boost. This consists of a pneumatic actuator connected to a valve assembly mounted inside the turbine housing. By connecting the pneumatic actuator to boost pressure, the turbo is able to limit its maximum boost output. The net result is increased durability, quicker time to boost, and adjustability of boost.clear.gif
What's the difference between internal and external wastegates?
Internal wastegates are comprised of a flapper door which is built in the turbine housing, usually operated pneumatically by a mechanical actuator. These flapper doors are limited in size, but work well in certain applications. Usually found in smaller turbos, internal wastegates are relatively inexpensive, simple in design, and very durable. Larger turbo can be fitted with internal wastegates, but boost control can be tricky. If you are looking to run high boost (20+ psi) all the time, then an internal gate may be fine. If you are looking to run lower boost levels, you will need an external wastegate.
External wastegates are generally mounted to the exhaust manifold or to the O2 housing, and are self contained units. External wastegates have the ability to bypass large amounts of air, and can provide steady boost control at any pressure level. A common myth is that in order to run higher boost pressures, you need a larger wastegate. This is incorrect. Larger wastegates are necessary to run low boost levels on large turbos.
so would it hurt to put a large waste gate on a small turbo?
One thing is that large high mount external gate turbos are hardly stealth installs.
Pop the bonnet and everyone, esp. cops will know the car is 'off its teats'.
Also I note that many people love the high mounts and big gates so that they can run a screamer pipe that is also illegal.
But to make serious hp - say around 300rwkW, you pretty much need an external gate system.
T.
Ditto Abo.
Thanks B-Man :D
Is their a recommended brand/model or are all the Japanese brands similar in quality/performance ?
Ben, I have never heard a bad report on the performance of an external gate - they are pretty simple devices. (yet expensive)
Known Brands are:
Trust / GReddy
TIAL
TurboSmart
HKS
    • Oh my god, I feel sick. So much second year uni formulas and crap in that for modelling a sprung and dampened system. Blergh!
    • I see a Toyota 86 that has been molested by an Audi (thinking R8 ish) and a Hyundai.
    • Hey Prank, Any chance you could easily lock all the old FS and WTB posts? Even if it's just a one off hit through there. The majority of posts are people asking someone if they still have something for sale from 8+ years ago, when the person who originally advertised it hasn't been on the site in donkeys years. Just a thought I had. Maybe go through and lock everything older than 12 months or something?
    • I'd be thinking it's the other way around. Less of an impact when rich compared to lean, but definitely in a lean condition the cat specifically uses up a lot more free oxygen. When rich it's grabbing oxygen from other places to like NOx, but it still gets converted to CO2 and H2O.
    • Sorry yeah - My post was a mess and I attempted to fix it. In my example both sensors are post-cat. I realized later that I had literally pulled the motor apart and we saw no evidence of any knock and everything was sweet, so my WB was likely accurate (enough!, if anything the engine looked a little rich) In your example I'd want to recalibrate both sensors. I realize this is not possible in the real world. Best you can do is: 1) Calibrate current sensor 2) Calibrate a brand new sensor in same location (do you have an older one to compare to? Or is this a new purchase) Observe any changes in readings. I always thought it was 1M, I am clearly out of date. Mine is likely 2m+. I didn't want to have to choose one bank over another in my application.
