Hey guys,
A few days ago the check engine light came on, on the way home the other day it started suring and running extremely lean as per Air/fuel ratio gauge, no power.
So i done the ECU diagnostics fault code and looks like it appeared as the Oxygen Sensor, (this only occurred after heavy rain so thought this may have cause this) removed airfilter and airflow meter and cleaned them, cleaned the plugs on the O2 sensor as well, reset ECU and tested the next morning.. suring has now gone.. and it's not running really like like it was before./ now between rich and lean. However after a few minutes of driving the check engine light is just flashing slowly.. I can't seem to figure out this code? 11 maybe?
Anyone an expert on fault codes or is this still stuck in diagnostics mode?
R34 RB25DET Neo engine.
Thanks,
https://www.sau.com.au/forums/topic/438418-check-engine-light-after-ecu-reset/
