Alright guys,
Im moving house in a month or so and have some stuff laying around that needs to go.
R33 GTR series 1 headlights - Good nick, work good, removed to put series 3 headlights on. $350
R33 GTR/GTST dash facia - good nick, no broken clips. $100
1 Enkei RPF1 18x10.5 +15. Want a spare wheel for that one time when you hit a pot hole and cant fork out $400 for a new wheel? Buy my single wheel for half the price and have peace of mind that you will never keep that faithful car of yours off the road for too long. Tyre not included
$250
Intercooler piping. In great nick. No tears, no rips. Only replaced because hard pipe kit = 10 extra kw. $100
3.5" exhaust.
Custom made stainless steel 3.5" straight through with a chrome tip.
If you want a great flowing exhaust that does not drone and you dont want a cannon then this exhaust is for you.
It has travelled 100km, and has not even gone through enough heat cycles for the mufflers to bed in. It is tucked up higher than the jap exhausts and has zero step downs in it. So you know that you can get great flow out of this exhaust.
I paid a pretty penny for this and am selling it at major discount. Postage Australia wide is no problem, but you pay the postage.
If you do not think this is a good price, then I applaud you to contact some muffler shops and ask them how much it costs to make one of these stainless systems.
$1000
R32/R33/R34 Y pipe, front pipe. 3" - 3.5" mild steel. No holes, no gouges, flowed 340kw all day every day. $200
And that is that. Take my shit. Im asking too much? Offer me something... Paypal is fine. I have this.
Contact me on 0403 568 217 if you have any inquiries
All items are located on the Central coast NSW.
2a87c793-883b-4032-af70-67029e210882_zps
Alright
Headlights sold
Wheel sold
Front pipe pending
intercooler hoses pending
3.5" exhaust ***PRICE DROP*** $800
No one wants a stainless true 3.5" exhaust? Make me some offers I need this gone
  • 4 weeks later...
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
