[Nsw] Stagea Rs 267Kw On Safe Tune (Factory Rwd)
Yeah, see....when you have this vs. this Then you get me recommending to just take it to an auto-electrician to save the possibility of setting it on fire.
If you're using resistance mode on the multimeter of course plugging it in with a live battery won't yield a useful reading. Either disconnect the 12V while you do resistance testing or look up what the voltage should be for your current level and chase it back to the gauge cluster to isolate where the failure happens. -
Thanks, I checked from the back of the cluster and no reading there. I undid the connector and plugged in the wires directly to start from where I'm getting a reading: https://imgur.com/a/W8JI6Yr Weirdly enough when I tried to get a reading from the crimps that connect to the fuel pump assembly, I got nothing. Not sure what's my next step as I have admittedly limited knowledge with electricity.
