Hey guys, recently and finally departed with my beloved 33 after 7 years and had to strip it back before sale...
everything perfect working order and all bits included to bolt to stock manifolds or top mount and guarenteed to put a smile on face :D
Kando tdo6sl2 turbo and Tial MVR 44mm Wastegate
Comes with modified or standard rear housing..with modified housing the wastegate sits on top and will bolt to your stock manifold, looks real neat too...or if you are planning to top mount I can provide a stock turbine housing instead...less than 5000kms on it..made 265kw @ 1 bar on fuel capable of more, But I tuned for E85 where it made 303kws @ 17.5.. I think we hit a restriction after that, I didn't bother try find it as it was plenty fast enough for me....very quick, responsive and powerful setup
Comes with dump that bolts directly to 33 front pipe, spacer plates gaskets and all the oil, water lines, and fittings needed...
1900152_10152280105571499_1745701579_n_z
Adaptronic Select plug in
dont waste your time with silly afms or boost controllers , This ECu does the lot...boost control, onboard MAP, launch control, flex fuel, etc etc
Just plug in and play...comes with lines and even a few tunes to get you running if you buy the turbo injectors package deal..
1957985_10152280130731499_717331614_n_zp
750cc Xspurt Injectors rail and SX reg
Custom made to fit under a standard rb25 intake plenum,,these injectors work great with good economy and effiency..
pics here
http://www.skylinesaustralia.com/forums/topic/403711-top-feed-rail-in-r33-with-stock-plenumyes-it-can-be-done/?hl=%2Btop+%2Bfeed+%2Brb25
So there it is, take it all, bolt it on and you're ready to rumble.. Asking $2800 for the lot..prefer to sell as package, but willing seperate if it doesn't.
PM or 0415 121 985
Cheers..
David
  • 3 weeks later...
Ok Ecu is gone...taking offers on Turbo and gate...
Also have set of 6 Splitfire coilpacks I forgot to advertise...work perfect...gotta be worth, I dunno 350$
Turbo with stock rear housing 600$
or
With modified rear housing and gate 1000$
either way it will come with dump pipes, oil and water lines, fittings for block and spacer for manifold..so is ready to bolt up to any rb20/25...
splitfire Coilpacks 350$
Injectors I'm probably keeping them now for my JZ..but for $800 will sell the lot cause the rail is useless to me now...
Cheers.. :)
  • Like 1
  • 1 month later...
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
