For sale (Brisbane)! 07/1999 Nissan Stagea RS4(S) factory 5 speed manual - $10,500 ono
Kilometres 152,XXX
Colour Silver (Nissan FAST code: KR4)
Interior Colour Black (Nissan FAST code: Z)
Transmission 5 speed factory manual
Body 4 door 5 seat WAGON (WGNC34)
Drive Type 4WD + ATTESA
Engine 6 cylinder Petrol Turbo 2.5 L (2498cc - RB25DET Neo6)
* Fresh 6 months registration
* Dayz Edition bodykit
* Factory Xenon headlights
* No sunroof - a bonus as it can’t rust out
* 19'' SSW wheels with good tyres
* Tein coilovers on the front - sits about 3” lower than stock
* Professionally lowered springs in the back - sits about 2" lower than stock
* 3" split dump pipe from turbo
* Hi-flow cat
* 3" cat-back to 3” twin pipes
* NisTune - recently safe daily tuned @ 12 PSI max (~210hp at all four wheels)
* up-rated fuel pump
* Splitfire coil packs
* Front drive shafts
* New belts including timing belt, new plugs, new oils
* K&N air panel filter
* Front strut brace
* Front mount return-flow intercooler
* After-market triple-core alloy radiator + new cap
* Alpine MP3/CD/USB
* After-market Excedy heavy duty clutch
* All original floor mats + boot plastic mat
* Autowatch immobiliser system installed by Chris Rogers @ Audio Express
This is a genuine factory RS-Four S which means that it hasn’t had an automatic->manual conversion.
I have paperwork from JOC (Japanese Odometer Check - http://jdmodocheck.com/) which shows the registration cancellation date in Japan was 13th April 2007 with the last reading of 56,300KM on the odometer in 16th November 2004. This further reinforces that the car has done a genuine 152,XXXKM with ~96,000KM in Australia.
Reluctant sale to free up funds to complete my project car. This car does not attract unwanted police attention and drives beautifully on the highway and in traffic; which I have done for the last two years travelling to work and back with some coast trips on weekends.
An excellent cruiser that has the pickup when needed and loves mountain roads.
Easily pass RWC and can be supplied upon agreed sale.
Contact me via PM, e-mail: [email protected] or SMS 04-three-2 3-two-7 1-eight-7. Calls during work hours may not be answered
www.stagea.com.au if pictures don't work here
Edited by wookster
https://www.sau.com.au/forums/topic/444078-qld-1999-stagea-rs-four-s/
  • 1 month later...
  • 2 months later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
