Hey guys!
Was curious to know, as i'm about to start on my rb25/30 build what things will i be needing to know and was there any headaches i can avoid? Anything that will be needing to be custom made or anything i will need to plug or create into the engine block?
Any infomation on this build will be appreciated.
Thanks guys!
https://www.sau.com.au/forums/topic/444896-my-r33/
Use the later block with the water and oil outlets on the hot side, they also have a flat tensioner area in the front.
Earlier ones have the oil and water outlets cast on the block but not drilled and tapped to take fittings, some also dont have a flat tensioner area on the front where the water pump is.
Block is 38mm taller so expect to extend your piping.
There is a well written detailed write up on it, study it.... http://stevenwelsh.site.net.au/RB30_DOHC.pdf
https://www.sau.com.au/forums/topic/444896-my-r33/#findComment-7323714
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
