Parts cleanout, all parts brand new except where stated otherwise. Parts located Bundaberg QLD. Small parts (less than shoe box size) free postage, larger parts contact me with your location for shipping quote.
NEW -
6boost highmount, split pulse single w/gate exhaust manifold heat coated - $1000
Garrett GTX3076R .82AR V clamp exhaust housing (tapped for 1/8 exhaust temp probe) comes with fitting kit - $1700
Turbosmart turbo beanie - $200
Turbosmart 50mm Progate black - $550
Turbosmart dualport BOV black - $300
Turbosmart fuel pressure regulator FPR800 black - $200
Turbosmart fuel pressure gauge - $30
BMC twin entry airfilter - $90
DW300 E85 compatible fuel pump - $120
Splitfire coilpacks suit NEO - $450
Grex/Speco/Aeroflow oil cooler kit - $450
SX replaceable element 10 micron fuel filter - $100
Cusco BMC stopper painted black - $80
HICAS lock bar suit series 2 Stagea and others painted black - $50
Nissan S14 throttle cable suit FFP conversion - $60
SECOND HAND -
Blitz Dual SpecR boost controller still in box, as new condition - $350
R34 GTR intercooler excellent condition slightly modified - $300
Q45 TB modified (wax pellet cold start removed, shortened) includes TPS and wiring, comes with mounting gasket - $150
Edited by 3Katz
  • 3 weeks later...
NEW -
SECOND HAND -
Blitz Dual SpecR boost controller still in box, as new condition - $350 - SOLD
Q45 TB modified (wax pellet cold start removed, shortened) includes TPS and wiring, comes with mounting gasket - $150 - SOLD
NEW -
Turbosmart 50mm Progate black - $550 - SOLD PENDING PAYMENT
Turbosmart fuel pressure regulator FPR800 black - $200 - SOLD PENDING PAYMENT
DW300 E85 compatible fuel pump - $120 - SOLD PENDING PAYMENT
SECOND HAND -
NEW -
Garrett GTX3076R .82AR V clamp exhaust housing (tapped for 1/8 exhaust temp probe) comes with fitting kit - $1700 -SOLD PENDING PAYMENT
SECOND HAND -
NEW -
SECOND HAND -
Good parts here guys get in while you can...
NEW -
Garrett GTX3076R .82AR V clamp exhaust housing (tapped for 1/8 exhaust temp probe) comes with fitting kit - $1700 - SOLD
SECOND HAND -
G'day Mick you contacted me on my intake kit thread mate. Still bolts up perfect to a NEO :) I'm pretty sure it's sold now though just waiting for money to arrive. I do still have the black twin entry fuel rail though and the 1000cc injectors....
I bought the turbo off this guy.
Very genuine seller and ships your items quick
Glad to hear it got there aleady Dan, cheers mate.
Hey mate.. any chance I can grab the grex sandwich plate? If so then how much to brisbane 4113?
Sorry Dave, it comes as a package with the lines and cooler - good buying though, pm me an offer if you like :)
Edited by 3Katz
Turbosmart fuel pressure gauge - $30 - SOLD
Splitfire coilpacks suit NEO - $450 - SOLD
Nissan S14 throttle cable suit FFP conversion - $60 - SOLD
SECOND HAND -
R34 GTR intercooler excellent condition slightly modified - $300 - SOLD
Edited by 3Katz
bump for great seller.
Cheers buddy :thumbsup:
Grex/Speco/Aeroflow oil cooler kit - $450 - SOLD
Cusco BMC stopper painted black - $80 - SOLD
HICAS lock bar suit series 2 Stagea and others painted black - $50 - SOLD
SECOND HAND -
6boost highmount, split pulse single w/gate exhaust manifold heat coated - $1000 - SOLD
SECOND HAND -
  • 1 month later...
BMC twin entry airfilter - $90 - SOLD
SECOND HAND -
Only a few items left - reduced, price includes postage.
Turbosmart turbo beanie - $200 $160
Turbosmart dualport BOV black - $300 $260
SX replaceable element 10 micron fuel filter - $100 $90
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
