I was just wondering if anyone happens to know how many quarts of ATF are supposed to be but in a tranny for an R32 Gtst. I already replaced it once, and guess i didn't get enough fluid in it (even though the dipstick said there was enough) because about a month or 2 later, the transmission was totally shot once again. I'm just wondering, because I'm running out of transmissions to put in it.
Also, does anyone know if there is a gear ratio difference between a tranny for a GTS and a GTS-t?
Thanks in advance.
Lucas
https://www.sau.com.au/forums/topic/44977-transmission-question/
