AAAA HA !---thanks for that------more dodgey shit , I'm starting to go of the idea of buying any import somewhat when I read articles like these there's a load of stuff on whirlpool as well on the 'clocking' hobby so beloved of import dealers .
I've had 3 imports over the last 7 or 8 years an R34GT-t from a dealers opposite Zupps on Ferry Rd ,GC, since changed hands was all good but an RX7 FC3C from MJR that was on Ferry Rd GC turned out a pile of steaming and the subsequent who-ha with the dealer was beyond an education , I got a 180SX-X from the a Ford dealer in Lismore that had a few issues that ended up in QCAT so two out of three have been a pita.
It's like playing Russian roulette with someone else's gun and only your $15k on the table.
Looked at importing the model you want through Iron chef?
Yep , they have a top rep and I've been talking to Troy , I'm procrastinating on which way I should go for the best, my budget is limited to $15K absolute max that's on road done and done including transfer fees stamp duty ,rego , bloody tyres and all the bullcrap inc.
I also don't want to be contending with a full service , ie gearbox/diff/s/engine/brakes/filters/plugs , etc etc on top straight away ether.
So I'm thinking I may be better buying already onshore with a bit longer K's but servicing under control.
It may be that a good 04 350GT just can't be done on a budget this small , I've also been looking at the Mits EVO VII GTA as I like the specs on this one a lot and it may be just a bit more do-able.
Here's another 'clocking' link just bye the bye http://forums.whirlpool.net.au/archive/2246786
Edited by BASHO
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
