Hi All,
Sadly sold the old girl earlier this week and have a number of parts left over which weren't included...
My prized possession are the TE37's, so I'll start off with this. The rest will follow soon (watch this space).
These are mint, basically brand new (as new). Not a flaw in them. Will let the pictures do the talking but will post more of them up this weekend. Current pictures are on the car, which obviously is no longer the case as the car is gone.
post-25413-0-85615200-1423743267_thumb.jpgpost-25413-0-40323500-1423743271_thumb.jpgpost-25413-0-99283600-1423743274_thumb.jpgpost-25413-0-10010200-1423743278_thumb.jpg
Specs are as follows...
2x 17x9JJ+15 (Bridgestone Adrenalin RE001 215/45R17 at 80%)
2x 18x10.5J+22 (Bridgestone Adrenalin RE002 235/40R18 at 95%)
4x Rays Eng center caps
4x Rays Eng hub rings (73.1Øx66.1Ø - Suits Nissan hubs)
Colour of the rims are genuine Rays Eng Matte Black. These were custom done by Rays Eng which incurred a hefty wait time, plus additional costs for the colour. Furthermore, I got these when Rays Eng updated the TE37's to show their branded (e.g. Rays Eng, Made in Japan, Forged Monoblock) on the rims to counter the wannabe/fake/inferior/copied rims mass produced.
I have noticed that the finish on these are so much more durable than getting them resprayed in retrospect. I've experienced this first hand when I previously had an older discontinued pair of TE37's which were originally bronze, sprayed by a professional shop to matte black. The colour on the lips chipped very easily and looked ghetto as. The finish of the paint around the wheel nuts also came off even though it was professionally done. Whereas,
the original Matte Black done by Rays Eng haven't got any chips or defects in the finish whatsoever!
Anyhoo... Looking for $3k ono for the lot including the rubber. Not keen to separate the rims and the rubber as I'll have no use for the rubber.
Pick up in Burwood East, VIC. Happy to courier but you need to organise it!
Contact via sms preferred on zero four two one 1 2 1 eight 1 eight.
Cheers,
Andy
Bump!
Had a few people keen but no one's come up with the goods yet...
Cheers,
Andy
Edit: Oh and an update on the rubber on the 17's... There is actually a bit of inner camber wear on the pair. Price still stands as I am basically giving the rubber away free with the wheels. Rubber on the 18's are basically brand new. Price is nego within reason. Low ballers will be ignored.
Edited by AnDyStYLe
  • 1 month later...
  • 4 weeks later...
  • 3 weeks later...
Bump!
Willing to post to anywhere in Australia via courier... If I remember correctly, last time I sent a set of wheels to Sydney it was about $100 although that didn't include rubber.
Give us your postcode and I'll get a quote!
Cheers,
Andy
  • 4 months later...
  • 3 weeks later...
Bump and price drop... $2.4k
For a full set of immaculate and original TE37's (NOT resprayed), this is a steal. Just needing to make space in the spare room, so these need to go.
Cheers,
Andy
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
