Hi All,
Sadly sold the old girl earlier this week and have a number of parts left over which weren't included...
My prized possession are the TE37's, so I'll start off with this. The rest will follow soon (watch this space).
These are mint, basically brand new (as new). Not a flaw in them. Will let the pictures do the talking but will post more of them up this weekend. Current pictures are on the car, which obviously is no longer the case as the car is gone.
post-25413-0-85615200-1423743267_thumb.jpgpost-25413-0-40323500-1423743271_thumb.jpgpost-25413-0-99283600-1423743274_thumb.jpgpost-25413-0-10010200-1423743278_thumb.jpg
Specs are as follows...
2x 17x9JJ+15 (Bridgestone Adrenalin RE001 215/45R17 at 80%)
2x 18x10.5J+22 (Bridgestone Adrenalin RE002 235/40R18 at 95%)
4x Rays Eng center caps
4x Rays Eng hub rings (73.1Øx66.1Ø - Suits Nissan hubs)
Colour of the rims are genuine Rays Eng Matte Black. These were custom done by Rays Eng which incurred a hefty wait time, plus additional costs for the colour. Furthermore, I got these when Rays Eng updated the TE37's to show their branded (e.g. Rays Eng, Made in Japan, Forged Monoblock) on the rims to counter the wannabe/fake/inferior/copied rims mass produced.
I have noticed that the finish on these are so much more durable than getting them resprayed in retrospect. I've experienced this first hand when I previously had an older discontinued pair of TE37's which were originally bronze, sprayed by a professional shop to matte black. The colour on the lips chipped very easily and looked ghetto as. The finish of the paint around the wheel nuts also came off even though it was professionally done. Whereas,
the original Matte Black done by Rays Eng haven't got any chips or defects in the finish whatsoever!
Anyhoo... Looking for $3k ono for the lot including the rubber. Not keen to separate the rims and the rubber as I'll have no use for the rubber.
Pick up in Burwood East, VIC. Happy to courier but you need to organise it!
Contact via sms preferred on zero four two one 1 2 1 eight 1 eight.
Cheers,
Andy
Bump!
Had a few people keen but no one's come up with the goods yet...
Cheers,
Andy
Edit: Oh and an update on the rubber on the 17's... There is actually a bit of inner camber wear on the pair. Price still stands as I am basically giving the rubber away free with the wheels. Rubber on the 18's are basically brand new. Price is nego within reason. Low ballers will be ignored.
Edited by AnDyStYLe
  • 1 month later...
  • 4 weeks later...
  • 3 weeks later...
Bump!
Willing to post to anywhere in Australia via courier... If I remember correctly, last time I sent a set of wheels to Sydney it was about $100 although that didn't include rubber.
Give us your postcode and I'll get a quote!
Cheers,
Andy
  • 4 months later...
  • 3 weeks later...
Bump and price drop... $2.4k
For a full set of immaculate and original TE37's (NOT resprayed), this is a steal. Just needing to make space in the spare room, so these need to go.
Cheers,
Andy
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
