Kei Office R32 GTR suspension
Height and Damper adjustable, full aluminium, including hats.
2 sets of springs, original 600lbs front and rear, and king springs competition 450lbs front, 350lbs rear. Full setup for road, track, drift etc.
$1000 the lot.
Call, email, or PM with any questions.
Mark
https://www.sau.com.au/forums/topic/45427-fs-r32-gtr-kei-office-suspension/
Not sure, will have to check the label and see what is written. Post later tonight.
Picture up or fronts. Rears still on the car.
Note that these are the Kings Springs. The original springs are green.
Not sure of the model.
  • 2 months later...
I really don't know how to tell which model they are. It's not on the sticker. If you can point me in the direction of a website or something that shows the different models I could find out, otherwise I will have to contact someone in Japan to find out, and that will not be easy.
I can tell you that they are full alloy housings, including the hats, and have height and 4-way damper adjustment. I believe that some of the lower models have steel housings, so I think they are in the upper part of the Kei Office range.
As to why I am selling them, the car is now a pure race car, for competition use only. I've upgraded to some custom built suspension with ride heights fixed for my set up and built specifically for track use. There's nothing wrong with the kei office, I've just gone for some better (read much, much, much more expensive) stuff specifically for competition track use.
Mark
Hi Mark, still interested. Are they any of these?
http://www.driftspeed.com/suspension_keioffice.asp
How old / condition etc
I really want them for circuit work not drift - are they very stiff?
Looks like they are almost certainly the type-xr.
With the stock springs they are stiff, though not too stiff for track use. The Kings springs are softer, giving your kidneys a bit of a break! Seriously though for most use I suggest the king springs as they are more forgiving of mistakes.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
