The car starts up fine but the sound coming from the head is super unnverving. I'm wondering if I have a bent valve or something. I pulled the covers and I saw no sludge or anything. The oil is super clean (I changed it last summer and put 20 miles max on the car. it hardly gets driven). I know its tough to gauge what could be wrong with the vehicle based on sound but here is a video of the noise. Remember this noise is speed dependent.
https://youtu.be/HWnxb16Bfr4
What would my next course of action be? Would a compression test tell me if I have a bent valve or anything? She starts and idles fine and drives fine although the only driving I do is from the end of my driveway back into my garage. Took the valve covers off to see if I saw anything irregular such as sludge or anything but everything is super clean. Like I said since putting this motor together, i've put a maximum of 100 miles on it in 2 years since I finished the car.
I'm from the states but I figure I would ask you guys because you guys see these motors more than we do here in the states. Any info would be much appreciated.
Sounds like there's two different noises, one when put under sudden load at 0:05 which sounds like a knocking, that noise ive never heard before, the ticking noises I would bet are the lifters , maybe a few have collapsed and not pumping back up..
What was done to the head/motor when built? are you using big camshafts?
Brief history of the car. Did fresh internals of the motor. Bottom end was completely worked over. Head is just ported and polished. I put it in the car and life happened and so the car sat more than it was driven. Camshafts are stock. I want my toy back so I am starting to get back into the car. I believe the timing might be a tad off so that could be the knocking you hear. I'm hoping the ticking/knocking is lifters. I plan pulling the lifters this week and seeing if I can clean/revive them. and putting things back together. I also notice that one of the bolts was snapped off the cam angle sensor.
Its been so long since I've worked on the motor that its kind of scaring me to get back into it. Mainly getting the timing right such as getting this at TDC and what not. I've read that I don't want the motor at TDC when I reinstall the cams. It's scary stuff to get in to. The last go around I had someone who knew what he was doing but he has since moved away. It also helped that the motor was out of the car. I'd rather not have to pull the motor if all I am fixing is lifters and timing the motor correctly.
Does it have good oil pressure and the right viscosity oil?
I've always put 10w30 in it but might oil pressure gauge is a little suspect (it was used). I'll buy a new one right now. 10w30 is the correct oil I should be using correct?
Yeah my thinking is that when the lifters are held under load and sit for long periods is they get bled and stick in position? so will probably need taken out and soaked then pumped up with fresh oil,
There's heaps of threads on lifter problems on here and someone else might have more advise, but if mine id flush, then new oil, get the engine hot and let run for 20mins and see if the lifter free's up, keeping the revs low to avoid damage, but its your call really.
Edited by AngryRB
Yea thats my plan. Ill take the lifters out and work them as best as I can and then reinstall and see where that takes me.
Edited by Inline6Silvia
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
