Hey guys, selling my R33 sedan to fund other projects. specs are as follows:
R33 Sedan, sexy 2 tone. little rough but in pretty good condition. there is a dint in the drivers rear quarter panel from tyre de-laminating, and a bit of damage to the rear of the bonnet from catching on the guard when opening it..
ENGINE:
SR20DET from a s1 s14.
new rocker cover gasket, and front and rear main seals, exhaust gaskets, turbo studs and lock tabs.
EGR deleted
GKTech rocker stopper kit
braided turbo lines
Midnightmods oil cooler kit (tomei style block, remote mount filter, medium sized cooler & braided lines)
Midnight mods extended sump
ASI radiator with BA thermofans and temp switch
mid mounted intercooler with stainless piping
stainless intake pipe with pod filter
Midnight mods bellmouth dump pipe, full tucked 3 inch exhaust, centre offset rear muffler with twin stainless tips
walbro 460 fuel pump
DRIVELINE:
S14 5 speed gearbox with GKTech shifter bushing and new shifter seal
exedy heavy duty button clutch
GKTech braided clutch line
1 piece tailshaft with new staked unis
4.3 shimmed LSD
SUSPENSION & BRAKES:
BC coilovers
custom JDI knuckles (my design to suit my driving and ride height)
GKTech caster arms
boxed and braced caster arm mounts
GKTech traction arms
GKTech rear camber arms
GKTech rear toe arms
S15 rear cradle (braced toe arms mounts and LCA mounts)
Midnight mods solid cradle risers
R33 GTR rear swayer with new link bushes
Standard R33 turbo brakes all round with near new bend pads
INTERIOR:
Velo gtp90 drivers seat on custom rail
velo passenger seat on custom rail (bit rough but does the job)
nardi deep corn 360mm wheel with 3 inch spacer
basic half cage (can still use the rear seat)
fire extinguisher
full set of genuine floor mats
dash all works with the SR20, though the boost isn't hooked up, and the speedo is wrong (comes with a jaycar speedo corrector)
WHEELS & TYRES:
enkei RPF1 all round, painted to match the lower dark grey
FRONT: 17x9 +22 plus a 15mm GKTech spacer running 215/45 kumho ku31 tyres
REAR: 18x9.5 +38 running 235/40 worn tyres
there is probably stuff i have forgot, but here is a link to the build thread: http://www.nissansilvia.com/forums/index.php?showtopic=536352
most of the parts that went into this build have only done 1 track day and very little street driving. there is really nothing to spend, just jump in and drive.
it also comes with the stock exhaust, stock steering wheel, stock struts with king springs, and a snapped in half type m front bumper.
it is also defected, so will need a roady, come with no rego also.
I'm after 10k and the car is located in country victoria, 2 hours east of melbourne.
my number is 0438319875, thanks for reading
PICS AND VID
1981970_719809254720582_1746187567_n_zps
  • Like 1
https://www.sau.com.au/forums/topic/456065-sr20-powered-r33-sedan/
I'm not a fan of the steering wheel but that is a pretty sweet car. If I had the money spare I'd look into it but currently saving up for my Stagea.
Love that SR20 engine but what was in there originally?
Edited by FireFox-89
Thanks mate, being over 6 foot it is a pain to fit into these cars with a fixed back seat and not knee the wheel every time i try and use the clutch.
Was originally rb25det and auto.
Also forgot that the rear knuckles have spherical bushes for the toe and traction arms, and urethane bush on the camber arm.
As well as the old trans cooler is now a powersteering cooler
  • Like 1
  • 4 months later...
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
