BOOSTD: wrxhoon's name is jerry ;) and his best times were 12.07(pretty sure) but i know he ran 12.1.. apparently his last run was shit (after i left) so u must have seen that :D
terminal speed was 120mph on his best run, but with a crappy 2.0something 60 foot time, so could be a lot faster!
That m coupe was crazy! sounded good...and backed it up :)
BOOSTD: wrxhoon's name is jerry ;) and his best times were 12.07(pretty sure) but i know he ran 12.1.. apparently his last run was shit (after i left) so u must have seen that :rofl:
That m coupe was crazy! sounded good...and backed it up ;)
yea you are right arup best time was 12.069 @120.24 mph and 2.017 60 ft
that was the run i had with bill ( butthead ) he ran [email protected] mph and 1.866 60 ft .
bill ran 12.1 on his last run .
on my last run i got a good start 1.873 60 ft but then hit the cutout anded up running 12.333 @115.89 mph
on an earlier run i did 12.157 @119.87 mph and 2.089 60 ft ( bogged down on that run not enough rpm and dropped the clutch to quick .
it was much easier to take off with the smaller turbos .
it must have been very slippery today though , mick could only get 2.0 6o ft ,
last time we went he got 3 runs 1.8.. , 1.8.. and 1.7...
ah well i'm goping to have another go at 11 pass sometime in the near future ( went so close today i'm sure i'll get it )
next time u will hopefully get the 11 sec pass, it is a definite possibility...coming down to the launch and how slippery it is i guess!! it was great to watch, cant wait to have a run myself (when i actually get another car!)
Im not even going to bother saying what i got other than pissed off with numerous things. Good thing u didnt come up jase was a waste of time. Organisation was shit and i arived at 3:30 and only got 2 runs after 2.5 hours in the scrutineering line. what a ****ing joke!!!!!!!
One good thing was that I had a few words with the events co ordinator and also with Jim Reid himself and let them in on a few problems going on in the night that with some work could improve things for everyone in the future. Heres hoping it does!!!!
I guess ill just have to wait till the next street meet and see if anything changes.
Cheers
Scott.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
