I recently replaced my speedo cause the other broke in my Nissan skyline r32 gtst 1993. The new speedo all works, when the car is started the power steering works fine but after a little drive for about 30 seconds if that the steering goes heavy?
I've had a read about some sensor but I have no idea where it is and what to do about it ?
Any help would be great thanks
Have you back tracked? Ie
Take the cluster back out and check all connections. Apparently the sensor is at the back of the dash and the steering angle sensor is in the column.
Put the old cluster back in and see if you have power steering back.
Process of elimination.
Check your power steer reservoir.
The sensor behind the dash is the one coming from the gearbox. It's a big round hole with a small shaft sticking out of it right behind the gauge cluster. That's where the speego gets its reading from. Funny that your speedo works but you get heavy steering as usually when that pin breaks and car no longer receives a speed signal is when you get the heavy steering.
You might have to do a HICAS diagnostic test and see what comes up.
Have you had a look at the fuses?
All I could point my finger at this point is some kind of a bad connection...
Since you're using a lock bar like me, do you have anything unplugged from hicas ecu? Silver box under the parcel tray.
To get into HICAS diags:
1) Switch ingition off, transmission in neutral or auto in Park.
2) Start engine
3) Very quickly (with a couple of seconds), turn the steering wheel left and right about 20 degrees from centre five times, and then pump the brakes five times, then press the brake pedal once more - this will enter diagnostic mode.
4) Drive forwards or backwards about 5 metres at a speed less than 10k/ph, this will enter full diagnostic mode.
5) The HICAS light in the instrument cluster will be flashing quickly (for normal) or will flash a code indicating any problems. Long flash = first digit, short flash = second digit. Diagnostics will return to normal after five minutes, or any speed over 10k/ph, or ingnition is turned off.
Result codes:
11 HICAS control unit
12 HICAS motor power supply not present
13 HICAS motor output not present
21 Vehicle speed sensor not present
22 Steering angle sensor not present
23 Steering angle sensor neutral or not present
24 Rear main sensor input not present
25 Rear sub sensor input not present
31 Parking brake sensor input not present
32 (Auto) Inhibititor switch input not present
(Manual) Neutral switch input not present
33 Engine speed signal not present
Edited by ErOR
The lock bar was installed by the last owner so I'm not sure but I've owned the car for about a year and never had a problem till I replaced the cluster, I'll do the diagnostics and see what happens, I did an ecu diagnostics and it was all okay
What sensor are you testing?
The item on the column behind the steering wheel is the steering angle sensor and since you've deleted HICAS I can's see it having any input.
You swapped the dash and then your troubles began so to me it's a speed sensor problem.
The actual speed sensor is just a reed switch built into the speedo right where the cable enters.
There's differences between early/late models, so could be a wiring issue.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
