apexi avcr - brand new opened to have a look and then put into storage. $500
apexi bov - rare packaging from japan still intact, unit works fine is in used condition. $250
r34 gtt or gtr fog lamp brand new genuine never used $150
r34 gtt airbox and snorkel used condition $150
r34 grill - fpr series 2 bumber i believe or some aftermarket bumpers, $200
rays volk racong f zero challenge rims tyres like new size (2 x 17x8) (2 x 17x9) offset +40 all round sit flush with gaurds. $750
roh internation prowlers 20 inch, near new tyres, $750
Edited by ReeceGTS-T
Thanks for that mate I'm also very interested in your avcr it is the black edition yeah? It does contain everything yeah? Will talk soon if not sold before hand!
yes limited black edition but they are not that rare easy to pick up but are retailing still at around $750 plus. no worries send me a PM when you are getting serious about buying. no holds.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
