? Jdm Car Sales - Facebook Group ? Now In All Australian States & Territories!
Hey all,
After being an SAU member for quite some time now, I've noticed that quite a few members typically stay active within a particular sub-forum. :yes:
For example, being a V-Series owner and living in South Australia, I myself typically just stay within the V-Series sub-forum (and sometimes the Importing section) and that's about it.
I've noticed that unless you're actively looking to buy or sell a car, you probably won't be visiting the classifieds section... and I've found that from time to time I've missed out on a car that liked or a great deal. :glare:
So I've made a Facebook group called "JDM Car Sales SA" for those of you who are interested in knowing what's up for sale / or wanting to sell your JDM car to a specific target market (and not just everyone).
There are no ads involved, no fees or anything like that - and the group is just focused on JDM Car Sales (not parts or wheels for sale, or services for hire). ;)
If you have any suggestions or ideas to further improve the group, and benefit our community - please let me know :woot:
If you're interested in joining, please visit https://www.facebook.com/groups/jdmsa/ :wub:
*** EDIT ***
I have now created JDM Car Sales - Facebook Group for each State and Territory in Australia :)
JDM ACT Car Sales
www.facebook.com/groups/jdmact/
JDM NSW Car Sales
www.facebook.com/groups/jdmsyd/
JDM NT Car Sales
www.facebook.com/groups/jdmnt/
JDM QLD Car Sales
www.facebook.com/groups/jdmqld/
JDM SA Car Sales
JDM TAS Car Sales
www.facebook.com/groups/jdmtas/
JDM VIC Car Sales
www.facebook.com/groups/jdmvic/
JDM WA Car Sales
www.facebook.com/groups/jdmwa/
Cheers,
George
  • 5 weeks later...
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
