Hi my names Alex
Im after any info on anyone who has high/top mounted a op6 highflowed turbo and ran it external gate
Yes i understand that i could get a larger turbo capable of massive power figures.
Thank you
Here you go. Our Standard OP6 high flow profile. Internally and externally gated, All on E85 fuel
Rebuilt engine R33 engine with stock cams, and stock inlet manifold.
The most it made externally gated was 376rwkws
The most it made internally gated was 324rwkws
This result is more then 2 years old now. I can make it blow over 400rwkws today with similar response.
When using my thread, page 1 is an index page, Ctrl+F for searching criteria and that should take you to the corresponding page. It contains heaps of information in relation to turbocharger development as well as how and what supporting mods do to power curve.
1200cc injectors
600x300x75mm Front mounted cool
Brae high mount exhaust manifold
HPVA 50mm external gate
Xforce 3inch Cat back exhaust
100 Cell Cat
Profect B electric boost controller
4inch intake pipe
Adaptronic Plugin ecu
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
