As title states. Was out of r34 gtt and converted to push type using all brand new nissan items. Come wit shifter, fork, bearing carrier and rubber boots.
$1,400 ono
Can also supply at extra cost,near new direct clutch services extra heavy duty organic single plate clutch rated to 300kws and fly wheel to suit.
Also have a r31 manual conversion to suit.
Locations picton area, nsw. But can help deliver to syd.
Pm me or 0422772841.
https://www.sau.com.au/forums/topic/462762-nsw-rb25det-manual-gearbox/
