Hey guys, is there a somewhat easy way to remove HICAS on an M35 or do I need to ditch the HICAS subframe and get a non-HICAS subframe. I went for a spirited drive and its RRREEAAALLLYYY annoying. I know on the older HICAS cars you just buy the lock bar and swap around but the M35 HICAS is quite different.
Any help or tips is appreciate cheers.
https://www.sau.com.au/forums/topic/462975-m35-hicas/
Just unplug it and leave the light on?
I can't stand Nissan's 'wobbly wheels' personally, and suspect it increases the chances of cracked subframes, but some people can't drive with LSD diffs in low traction conditions I guess.
https://www.sau.com.au/forums/topic/462975-m35-hicas/#findComment-7684007
So there's no harm in just unplugging it for now and living with the dash light?
I can't stand it either, it felt like something was wrong in the back end especially during quick direction changes (well quick for 2ton wagon). Will look further intolerant non-HICAS subframe in the future
https://www.sau.com.au/forums/topic/462975-m35-hicas/#findComment-7684011
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
