Hey guys selling 2 V35's Skylines both low k's just need to go to wova
both cars repaired at a mechanical shop done perfectly zero issues
1 st all done just needs to be send to be finished
2nd car needs to have lower control arm and coilovers put in then finished
body kit for one car is there both start and run
Selling up due to finical issues doesn't mean I'm despite for cash PACKAGE DEAL ONLY
brisbane southside Inbox or
will give my number to serious people
low k's
$13,500 with all the parts you need to finish
https://www.sau.com.au/forums/topic/463097-2-v35-skylines-cheap/
If you got a spare VQ35 for sale ill be interested in buying a engine off you? Pm me if you like..
will let u know if these done sell
car listing $5000 starting
http://www.ebay.com.au/itm/-/161989738714?
Edited by newOne1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
