Nosure Posted February 7, 2017 Share Posted February 7, 2017 FS: New 1000hp fuel setup. Top brand. And aeroflow fittings 1. New Magnafuel pump mp4303 (good for 750hp e85 single pump continue duty. Flow about 500lph at 70psi) $600,new filter suit the pump: $70 2. New Radium High volume external pump surge tank. $600 3. New JMS FUELMAX single pm2000 40A (boost up voltage from 14v-20v adjustable and ramp in function, active when boost or 5v, much better than kennebell bap) $500 4. Used SARD fuel reg good condition with fittings. $100 5. New Aeroflow Kevlar braided teflon hose -6an 4.5m $220 6. New black hard line 1/2 (12.7mm) $50 7. New aeroflow 400 blue hose -6 an (3/8) 3m. $50 8. A lot New aeroflow fittings (an 6 8 10 12 full flow push on hose end, 8 orb-6 8 10an fittings efi fittings, 5/16,1/2 hard line fittings) want sale as a package. From $100 9. Tomei type A valve springs for rb26 (only test fit. $100 If buy pump, surge tank and fuelmax bap together. I can do a better deal. Or give you the fittings you need for install. And this is 1000hp e85 combination on single pump. One pump= less heat less worries. I change my mind, so no need these parts. They all genuine. Location: gold coast Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/ Share on other sites More sharing options...
Nosure Posted February 7, 2017 Author Share Posted February 7, 2017 If you find somewhere sale them cheaper I can make it even cheaper But im sure they are cheapest new parts already. Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7809788 Share on other sites More sharing options...
Nosure Posted February 8, 2017 Author Share Posted February 8, 2017 Fs: Id 1300cc e85 11mm rb26 Less than 600kms. Perfect condition. still on my car, if someone want them I will remove them after 13.02.2017 price:1000 Locate: gold coast Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7810019 Share on other sites More sharing options...
Nosure Posted February 8, 2017 Author Share Posted February 8, 2017 If someone want buy as a package I also can put a set near new id1300 for very cheap price. Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7810021 Share on other sites More sharing options...
Nosure Posted February 11, 2017 Author Share Posted February 11, 2017 I don't have enough money for id1700 so I might keep my id1300. ( If I want sale it again I will post up. unless someone want buy my surge tank setup then I can sale the injectors. Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7810566 Share on other sites More sharing options...
Nosure Posted February 11, 2017 Author Share Posted February 11, 2017 I also have 2x New aeroflow check valve for Bosch efi pump. $60 both Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7810595 Share on other sites More sharing options...
Nosure Posted February 12, 2017 Author Share Posted February 12, 2017 1/2 hard line sold. Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7810726 Share on other sites More sharing options...
Nosure Posted February 19, 2017 Author Share Posted February 19, 2017 Will swap my parts for garrett gt35 rear housing ( t3 ts 1.01) Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7812274 Share on other sites More sharing options...
Nosure Posted March 1, 2017 Author Share Posted March 1, 2017 A lot parts still for sale. 1. New Magnafuel pump mp4303 (good for 750hp e85 single pump continue duty. Flow about 500lph at 70psi) $600,new filter suit the pump: $70 2. New Radium High volume external pump surge tank. $600 3. New JMS FUELMAX single pm2000 40A (boost up voltage from 14v-20v adjustable and ramp in function, active when boost or 5v, much better than kennebell bap) $500 4. Near new turbosmart 1200 v2 fuel reg good condition with fittings and gauge. $120 5. A lot New aeroflow fittings (an 6 8 10 12 full flow push on hose end, 8 orb-6 8 10an fittings efi fittings, 5/16,1/2 hard line fittings) want sale as a package. From $100-500. 6. Id1300x e85 injectors 11mm rail. (Can be fit on different rail with different hats) only done 2 dyno run. $1000. Paid 1700 6. Tomei type A valve springs for r34gtr (only test fit. $100 Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7814232 Share on other sites More sharing options...
Nosure Posted March 8, 2017 Author Share Posted March 8, 2017 Id1300 Magnafuel pump and filter sold. Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7815876 Share on other sites More sharing options...
Nosure Posted March 27, 2017 Author Share Posted March 27, 2017 Update 1 New Radium High volume external pump surge tank. $600 2. New JMS FUELMAX single pm2000 40A (boost up voltage from 14v-20v adjustable and ramp in function, active when boost or 5v, much better than kennebell bap) $500 3. Aeroflow push lock fitting from 6an to 12an. Enough build one whole car fuel system with surge tank. And a lot other fittings ( orb fitting, hard line fittings, npt fittings) 4. Tomei type A valve springs for rb26 (only test fit. $80 5. R34 gtr cas used good condition $180 6. New turbosmart 1200 fuel reg v2 ( waiting turbosmart send back). $200 Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7820418 Share on other sites More sharing options...
Nosure Posted March 28, 2017 Author Share Posted March 28, 2017 Garrett turbo bag, used $70 Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7820551 Share on other sites More sharing options...
Nosure Posted March 30, 2017 Author Share Posted March 30, 2017 Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7821000 Share on other sites More sharing options...
Nosure Posted April 1, 2017 Author Share Posted April 1, 2017 still for sale:) Link to comment https://www.sau.com.au/forums/topic/468972-new-1000hp-fuel-setup-aeroflow-fittings-id1300-injectors/#findComment-7821425 Share on other sites More sharing options...
