Have a set of 370z 18 inch wheels for sale.
All 4 wheels are 18 x8, offset is +43, they're quality wheels made by enkei. One has some visible scratches.
All 4 wheels are straight, no buckles. 2 of the wheels have Goodyear eagle F1 245 45 tyres, the other two have nankang 225 50 tyres, with decent amount of tread.
$400 pickup only
superpro urethane pineapples, have opened package but never used
$70
Alloy subframe collar
$50
Tein S.tech springs - medium
They're the discontinued springs that have slightly higher spring rates than most lowered springs, 4.5kg/mm from memory. Works really well with decent shock absorbers such as bilstein, just don't need them anymore since I've gone coilovers
Suits r33/ r34 rwd models
$100 pickup only
Located in Sydney, lower north shore, happy to post unless specified otherwise
Edited by chiksluvit
I'll take the wheels. Could you contact me on 0468 330 099 as I can't see a number listed.
Just to confirm, the 370z wheels is a square set of 4 front wheels, all of them are 18x8 +43, will probably suit cars like elgrand, v35 v36 skyline sedan, stagea m35, etc
  • 3 weeks later...
Adding a used exedy heavy duty pull type clutch for sale, suits r33 gtr and r34 gtt, in good condition, with more than 60% meat left, pulled the clutch out because I have decided to change the setup
Comes with the following:
Exedy heavy duty clutch pressure plate
Exedy organic clutch disc
Standard flywheel used with this set up
new release bearing
New spigot bush
$150
  • 2 months later...
