I've had idle issues and noticed that the fuel trims max out (ST +25%, LT+10%) at idle, but look normal at other times. My guess is that i've caused an air leak when I installed Scottys cooling mod, which requires the manifold removal. I did pull the injectors out, so there could be a leak in a bottom seal or two, and i reused the gaskets (which all looked good).
Do you guys re-use the gaskets? Anyone know the bottom oring part numbers or the dimensions so i can get non-genuine ones?
https://www.sau.com.au/forums/topic/475771-nm35-fuel-trims-max-out-at-idle/
