EDIT: Well it turns out I'm an idiot and didn't notice that there's an adapter in the old turbo that needs to be swapped over to the new one... I guess this is a sign to get some sleep.
Hi guys,
I recently bought a pair of 2860R-5's (836026-5005S) and got them installed. When I went to go put in the coolant hard lines, it appears that the OEM lines are to big? It looks like the flared area of the coolant line wont even go into the port. I still have my old original turbos and the line fits up just fine on those. Did I mess something up here, or is the coolant port smaller on the 2860Rs? The ports do look different as well. Sorry for the bad pics as well. Not much room to get my phone in the engine bay.
Edited by ECHO_IV
https://www.sau.com.au/forums/topic/481004-2860r-5-coolant-hard-line-help/
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
