Rip a wheel off and look for a model number on the TEIN parts.. thats what I did then jumped on the TEIN website and found out what they could do. Mine are adjustable and I think most are. I have Dampening and Ride Height Adjustment..
Fulcrum Suspension centres are also helpful :) They were the only ones I found willing to adjust my ride height, darn car was scraping everywhere :P fixed now though..
I would also suggust getting your castor settings checked and leveled out, most skylines I have driven pull to the left strongly, which cause undue tire wear as well.
Good Luck
Aridyne
Ok, thanks mate.
I just wanted to confirm that there should be something written on the shocks before pulling things apart/off.
Need to get camber/castor sorted out also, but would like to know what I have before I start spending $. Would be nice if I could soften the ride a little, but I hear TEINs are still pretty hard on the softest setting.
Cheers
Good Luck
Aridyne
It seems I have TEIN type NR:
TYPE NR
Street spec
Well Balance
Master
DNN65-12531
ECR33-R
20012
From the TEIN site:
Type NR Kit includes:
Fixed Rate damper X 4, S-TECH Spring X 4
Detailed handbook, 90 mm measuring gauge, damper adjustment tool
C ring height adjustment equipment (4 levels) fixed damper X 4
C RING TYPE HEIGHT ADJUSTMENT MECHANISM
The C Ring Type height adjustment mechanism enables a wide range of driving variations depending on the situation, by changing the setting for weight balance, corner weight.
Base setting is 2nd from top. The position for the 4 steps are defined based on the model data and putting in consideration the lever ratio, is set to change by 10mm. However, if set in a position other than the base position, there is a possibility for spring space to occur or other problems from pre-load over.
http://www.tein.co.jp/nrdampe.html
So I can't change the dampening, but I can adjust the height between 4 levels using C ring height adjustment equipment (which I don't have).
Does this seem right? Are there any guides/instructions out there as to how to adjust the height?
John
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
