Gippsland Area
was hoping on driving out to trarlgon during uni hols, might meet up with ya if I can, I'll let u know closer to the day.
PS: what's there to do in trarlgon, coz i'll be there with the gf, and dun really know bout much that goes on over there. We're looking at about 12 noon to about 5 in the arvo, do you guys have any fairs or festivals comin up?
https://www.sau.com.au/forums/topic/5056-gippsland-area/#findComment-80608
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
