i got a garrett T3/T04b custom turbo, brand new it is oil and water cooled roller bearing the info for the turbo is T3 To4b . The compressor wheel is a 54 trim and the compressor housing is a 60ar . The turbine side is a 48ar with a standard T3 flange. this is pretty much a bolt on for a skyline rb2*det engines and also a VLT or anything with a T3 flange that has oil and water cooling, only problem is that the exhuast flange going to the dump pipe is different tho most exhuast can be modifyed for very cheap i am asking $950ono for the turbo if u would like pic's or more info please email me at [email protected]
Thanks
Is it internally or externally wastegated, what sought of power is it good for and ya got any pics
it is internal wastegate and give me ur email address and i will send u pic's when i brought it i was told by the people who built it that it should do 450-500hp
Thanks
.48 a/r turbine housing will need 20+psi to make more power than stock, will be still a struggle at that without an external gate. This turbo would be more suited to a CA. May be an easy option to bolt on your standard Turbine housing or even a VG30. will have a tonne more power at less boost and also bolt straight on.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
