Charcters on JDM plates?????????
Could someone please tell me what the character on the left of the numbers on Japanese rego plates mean?
I understand that the characters at the top of the plate denote the prefecture, I am simply curious what the single one means.
Thanks
ps. I put it here cause i figured you people living in Japan would know best......i apologise if this is not the appropriate place for this thread.
https://www.sau.com.au/forums/topic/52231-charcters-on-jdm-plates/
So it has no reference to vehicle type/mass etc?
Means nothing then?
that's the top numbers your refering to
- 500 (used to be 5x): depending on engine capacity, car weight and width which I don't know exactly but don't really care. As an example: most small sedans/hatches, coupes like integra, silvia, celica, roadster MR2/S, roadsters etc...early skylines, chasers, evos, sti, rx-7 I believe are in this class too.
- 300 (used to be 3x): same as above but larger, heavier class...NSX, Supra, GTO, GT-R, RX-7, Evo, Z32/33, RX-8, Chasers, Skylines, Stageas etc
- Yellow plates: kei plates... I don't take note of the numbers.
- 400: lorries, special vehicles
- 800 (used tobe 88): marked police cars and emergency services ambos, fire brigade
from what i heard here's how it goes, 2.1 liter engine and below is 500 plates, 2.2 and above is 300 plates, bus and trucks are 100. my wifes prelude is a 300 plate because its a 2.2 liter engine. thats the reason why r32 gts-t's and gts-4 has a 500 plate (and thats how u can tell if people just slapped in a gtr badge hehe).
the letter beside it doesnt really mean anything, except for us which is Y or E or A, which denotes (supposedly) tax free (but we still pay for it though, because the base commander "insist"). :bs!:
Yukio, as I said any of 3 main criterias I mentioned and also a few other things.
My Evo and a s14 are both 2.0L and have 300 plates...s13 and S15 are 500 plates...but it's no big deal. As you said only makes it easier to spot posers...but then I have seen RB26DETT in HNR32 with 500 plates.
Good that you mentioned it, I forgot about the 100 plates.
Also plates with a red diagonal line across the plates are dealer plates.
i think so too, but coz us here on US base we have different coding just to make it less complicated, they made it simple, yellow plates and motorcycles pay 3,000 yen, 500 plates pay 5,000 yen or some small number like that then 300 plates pay 19,990 yen then 300 plates with 4.5 liter engine and up pays 47,000 something yen for a year.
I thought the numbers, which denote tax code (right?) are also determined by the weight of the vehicle?
From what I have observed I think 300 plates are starting from 2.0L up capacity, 1200kg+ weight and 1700mm+ width.
Because the early Evos and WRX meets all of the above except for width and they are 500 plates...or the old 7x plates.
Justin I don't think the 1 has any significance, more they ran out of possible plates and just tag the additional digit to it....
I think the basic numbers, 1, 3, 5 etc are used and then each prefecture can add numbers after that dependening on needs...
so a 55 code is the same as a 500 code since they both start with a 5.
Over here in Yamanashi I've seen 55 / 500 / 501 / 33 / 300 / etc
One question - what the deal with a Kei car that has a black plate with yellow writing...not a yellow plate with black writing. Seen a couple about but could never figure it out.
Aaaah, I could be mistaken, but I remember someone saying the black plate with yellow writing is registered as a commercial vehicle...
as for the 5xx etc numbers - I asked that question at the dealership - was told that only the number of digits and the first digit are important - and that you could, in fact, choose the other digits if you liked
it was a 50:50 japanese/english conversation - it sounded a bit weird to me, so not sure if something was lost in translation
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
