mr180,
I just checked the Commander manual and it does say that the exhaust temp check light is used when there is a faulty sensor, however it goes on to say you have to use the commander to find out which sensor is faulty and replace it.... Not sure what is causing the commander to freeze on the Logo, is it brand new or second hand? Have you made sure the harness is nice and tightly plugged in??
Brett
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81598
Not sure if this is right or not, but I have heard that when you connect the PFC for the first time you have to deselect the boost control option if you are not running the boost controller or you get sensor errors as the PFC cannot find it (boost controller). If you do not have the boost control package, please disregard this post
Hope it helps
Steve
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81626
EVL R33,
Could you post that PDF file to [email protected] thanks.
The PowerFC I'm getting probably hasn't been used in a while, so that's why I'm thinking it could default back to the factory setting now. But I'll have to wait and see. Thanks anyway mate.
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81635
EVL R33,
It's second hand. Its plugged in tightly. The car starts up ok and idles... I dont think its the boost controller causing the problem as if it was it wouldnt start at all and I could at least turn the boost controller option off by using the hand controller.
Could it be the wrong commander?
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81656
Guest KILLER-T
Were the 3 commanders all off Nissan's? The info I have says that all Nissan power fc commanders apart from the r34 gtt are the same.
That can't be rite because Chris had a r33 gtst with a power fc He sold it and got a r34 gtt and used the same commander for it .
Sofar i have worked out that the commanders are not all compatable the older power fc's can only use the older ver commanders but the newer ver power fc's can use old or new commanders:eek1:
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81871
Originally posted by mr180
I just plugged my power fc in and it's stuck on the apexi logo... has anyone had this happen before? The exhaust temp signal is coming up, and the manual says that means one of the cars sensors isnt working, so maybe that's the problem? How do I get it working!?
You mean that the Apexi logo stay there? well, wrong commander for you..I have same thing happen before..
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81901
Silver, PDF is on its way... It won't reset itself, it uses ROM to store the settings so even with the power off for ages it should still keep the tuned settings. Reset it as soon as you plug it in just to be safe..
mr180, it does sound like you have the wrong commander. Nengun sells them second hand pretty cheap so it might be worth while picking one up, that way you never have to run around looking to borrow one...
Also you do have to turn the boost control off if you aren't using the PFC Boost controller, but that's simple once the commander is working...
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-82203
Thanks for your help!
Ok, so I guess I have a new controller and an old pfc... I still need to get a commander that works to see if the pfc is ok. If it's the wrong pfc then I will get a new one off Nengun. I'm getting another commander to try this week, so I will just have to wait and see if that one works!:D
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-82305
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
