I have these parts for sell in SA and please email me to [email protected] if anyone interested, thanks.
- R32 afm $100 used
- R32 driver side door trim $25 (few small holes on the side)
- R32 standard side skirts and rear pods $250 used (2 set)
- R32 stand rear wing with break light $25 used (dark blue, no damage)
- R32 front right hand side clear parker $15 (one screw hole missing, no damage)
- S14 Vertex rear bar $300 new
- S13 front lip $120 new
- 180sx front lip for CA18 $170 used (light blue)
- GT wing $180 new (black)
- Blitz auto turbo timer $100 used (very good condition, no damage)
*Plus postage for interstate order, and please ask for any photo, thanks.
https://www.sau.com.au/forums/topic/53654-fs-few-used-kits-afm-tt-new-gt-wing/
- R32 afm $100 used
Hey man may be interested in the turbo timer. Im in adelaide. Contact me for a meet. Thanks,
Gordon
0422107997
shogun, my number is 0402 452 455, and I can meet you anytime this coming week, but not Friday and Saturday. Is your phone Optus? Can you just think of a time and message it to my phone and then I can reply you, thanks.
