These look like Ferrari F40 rims and would look great on GTS/GTR 32,33. Unfortunately i only have 3 of em. So basically this is for ppl who already have these rims already but broke one of em (dats what happend to me) hehehe or anybody has one for sale, i would gladly buy one off!!!
Heres a pic
https://www.sau.com.au/forums/topic/53997-for-sale-17-speedline-rims/
what size's + offsets are they? and what price are you after? a pair of rims would be nice to throw some cheap rubber on the back for a bit of "fun".....depends on the price though :)
I will go check out the offset but i'm sure it'll fit R33 GTST. So basically all up $500 for:-
3X17" Speedline rims with 90% threads 245/45
1X17" Spare tires 245/45
Definitely worth it for spare drift mags
Offset is usually a number written on the back of the mag on one of the spokes any number ranging from 15->45 usually for a skyline gtr from 15-32+ offset
the width of the rim is usually written as 17 x 8JJ or 17 X 9JJ somewhere on the back as well.
hope i was helpful g'luck wif the sale
my 2cents
Thank you very much GTshortie! I will go home and check
my 2cents
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
