Does anyone know the guy who drives this car its a black r32 with the plates either GTS 308 or GTS 303 the guy is also on p plates.
Last night he nearly ran me off the road while overtaking me at about 900km in a 60 zone. He drives like a complete tosser...this was in the carnegie area......
:cuss:
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/
Not a bad looking car when stopped
yeah its a nice looking car but as we can read in other threads....
"guys in other skylines who look at you and think they are sick c..unts.. and also think they are better" they suck thats what this guy is
he is a tosser....also he has a fast car it has def been moded (as i saw it outside gts on dandy road) however when I pulled up next to him he didnt give me a friendly wave or a smile he just stared straight through me.... i dislike him argh
:headshot:
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83383
Righto. Will keep a lookout.
My Civic looks like a normal red Civic hatch (except it usually has bike carriers on the roof) :) Skyline has been ordered - but not here yet. Thinking 'AKIRA' for the plate?
The other car is more recognizable - Red Lada Niva convertible with 'EX-KGB' plate :)
I live in Sth Yarra - and have seen GTS-308 alot on Chapel St.
James W
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83390
need I say more
as i always say when down chapel(walking and drinking at pubs) look at these tossers trying to show off their cars why dont they just go on a sick drive and puch their car drive it how it is meant to be driven....eg: out to the dandeongs of out to geelong.. they use the same petrol and have twice as much fun,,,, wankers on chapel ......... PPFFFTTTTTTTTT:shake:
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83393
Ak:
> what does this mean what have you ordered tell me the specs
Series 3 '98 R33 GT-R Vspec
Midnight Purple Pearl
Stock to the max :)
Will add PowerFC and breathing system (filter/exhaust only) here.
I'm being very picky about the car and having a problem fiding one in the right colour. Lots of silver and white - but no purple :)
Getting it through GTA in the city - guy left a message for me today at the office - so maybe a good sign.
I don't spend $60k every day - so I'm not compromising what I want :)
Will keep you posted.
James W
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83397
drool drool
thats exactly what I want I knew...stressing "knew" a guy selling one of these for 55k it was sooooo nice I want a purple r33 gtr thats my next car...when you get it we;ll cruise uo to the dandeongs so i can show ur car up :) ...!1 pEaCE
https://www.sau.com.au/forums/topic/5402-gts-308-or-gts-303/#findComment-83398
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
