Hey guys time to sell my skyline..
This car has had alot of money spent on it and has been very reliable for me over the 3 years I have owned it.. Car was purchased stock..
1993 Nissan Skyline GTS-T
White with carbon fibre bonnet
Genuine GTR rear wing with carbon fibre wing blade and original wing blade
New Copy GTR front bar with genuine GTR indicators
17 inch white AVS jap wheels
Front mount intercooler with new silicon hose's
Turbo back 3 inch mandrel bend exhaust with 3 inch highflow cat into 5 inch angled cannon
GCG stage 1 (450hp) turbo - done 20,000kms with 12psi wastegate actuator upgrade
Haltec E6K ECU with Haltec coil pack and incabin boost control from 12 - 20psi
Turbo Timer
Autometer carbon fibre boost gauge - upto 30psi
C's short shift kit
Turbo smart type 3 BOV
Bilstein front / Koni rear adjustable suspension
Whiteline adjustable sway bars - front and rear
Lowered with king springs
Whiteline engine bay strut bar
Airpod
New bosch 600HP internal fuel pump
Malpassi rising rate fuel pressure regulator
New Heavy duty clutch
New machined heavy duty flywheel
New rebuilt engine just installed and run in under 1000kms old
Engine bored and honed - New venolia oversized forged pistons - Steel conrods - All engine bearings, gaskets, and seals replaced with genuine nissan parts
Crankshaft Linished and crack tested
Cylinder head overhauled
ARP head studs
Tomei head gasket
Tomei adjustable exhaust cam gear
81,xxx kms with service history from 35,500 when I purchased it
Serviced every 5,000kms or sooner with top quality lubricants
No expense spared - all reciepts for all work done
Much loved car will be sad to see it go..
If there is anything that I have not listed that you need to know let me know..
Car is located on Sydney's north shore
No time wasters / Joy riders or tyre kickers thankyou
UPDATE: New tyres - New heavy duty battery - 11 months Rego
UPDATED PRICE: $24000.00 FIRM
https://www.sau.com.au/forums/topic/54044-fs-syd-1993-r33-gts-t-skyline/
  • 3 months later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
