my local BP decided to jack the prices up over every other BP by 10c per litre yesterday.
Most BP's were selling their regular unleaded for around 93/94c per litre, but the one down the road from me decided they were selling it for $1.05 per litre. Filled up with ultimate from there (didn't realise there was that big of a price difference until after i'd filled up) and paid $1.15 per litre (Brisbane)
https://www.sau.com.au/forums/topic/54268-go-juice-prices/#findComment-1063662
yea i paid $1.209 for syndergy 8000... so i only put enough to get me through the weekend... It's bullshit how prices fluctuate throughout the week... I used to wor in a petrol station and I know how it works... It's just a local pricing war with lots of price matching. One place puts their price up, everyone else follows, when it goes down they all follow... I remember when the Litres where greater than the dollars :(
https://www.sau.com.au/forums/topic/54268-go-juice-prices/#findComment-1063962
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
