Mate what a storm!!!
About 1:30 - 1:50 am the wind is howling her tits off and hail and rain is pelting down. The carpark at work is 15cm deep in hail in some points and our store was leaking. Freaking mad, I was outside in the rain making hail balls as I've never seen snow and this was pretty damn close, it even made the crunch sound when you walked on it.:)
I am a simple, simple man:uh-huh:
https://www.sau.com.au/forums/topic/5477-whoa/
I got waken up by Window cracking sound this morning around 3:30 am... from under car park at my place.
so I thought farking thieves again so I took trusty Number 4 iron phone then went out side...
it was still dark and raining a bit also the wind was just too strong...
I go down there I saw my car was ok :) and other cars all ok exapt this one lancer parked quite far away from the enterance of building had cracked window on the passanger side. and that's it.
I did see anyone but I must been scare the theives away.
heheheh some asian dude, half naked and swinging number 4 golf clubs iron and shouting out, who wont be scared :eek1:
anyway I felt sorry for the owner of the car cuz he wake up this morning seeing the his car window is Broken... well I was not happy when my car got broken into...
fark I should tell people to upgrade te frekin car park!
anyway thanks for reading
cheers
Joe
https://www.sau.com.au/forums/topic/5477-whoa/#findComment-83644
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
