hey guys ....
i had this problem for two days now ...
the boost is only 4 psi ... !! its some times reach 5 psi ..
it happend twice befor ... but it was for 5-10 minutes and then it gos ...without shuting down the car .. !!
now its there for two days ... i donno ... :hellpisd:
any help plzzz !!
i did ecu check ..(55) every thing is ok .. (just in case)
mods .. pod , exust and splitfire coil packs with iridium ix plugs ... only
car: 1998 R34 GTT
helpppppppppppppppppppppppppppppppppppp !!
https://www.sau.com.au/forums/topic/54851-4-psi-only/
yesterday i checked the solenoid ... its dead i think .. any way .. i'v changed it with small valve i made .. to give 7-8 psi and it works perfect .. (temprory) tell i find new solenoid valve ...
by the way .. the r34 actuator opens the weastgate at 4 psi .. the valve i made bleeds some air out ..and reduce the pressure on the actuator (if any body intrested .. i can post some pic )
fazt-r33 : ... as rhett said ... on the stock gauge its normal to show 3-4 ... any way check u'r solenoid valve
https://www.sau.com.au/forums/topic/54851-4-psi-only/#findComment-1073979
thax omran... but is i normal to show the same after 4500rpm... i thoug ist meant to hit 7 on the stock gauge.......
also i got a stage 3 hydrid boost controller... with solonoid and all the works.. jst can frekn figure it out.. the diagrams are to shtty and 2 general......
apexi bov for sale.... ne1 interested... 2nd hand with the gtst adaptor... fits 32,33 & 34... interested...?
https://www.sau.com.au/forums/topic/54851-4-psi-only/#findComment-1074121
QUOTE]
If it hits 7x100mmHg on the stock gauge that means you are running about 14-15psi i think, or close to double the stock boost. You know, there are different units for pressure around, psi is just a more common unit. bar is probably used second most.
https://www.sau.com.au/forums/topic/54851-4-psi-only/#findComment-1075800
  • 4 months later...
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
