Idle
Guest VdubGuru
I have an R32 GTS-T Skyline and am having a bit of a problem. When idling the car idles at or around 800 rpm and drops to 600 rpm and then back up. It will do this every time after the car is warmed up. It also kind of stutters or stalls when you get on the gas really hard. It seems to have lost its power to go. Any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/5514-idle/
VdubGuru,
Sounds like the same problem that I had? I cleaned out the auxiliary air control (AAC) valve, and it worked!(reading these forums can be helpful after all)
Its located at the back of the plenum chamber (inlet manifold) there is a maroon electrical plug (brittle) and a hose which need to be removed first then there is four ten millimeter bolts that also need to be removed before the whole assembly can be (careful if you want to use the orignal gasket again) removed from the car.
then there is two screws that hold the solenoid on, once this is removed the remaining assembly can be cleaned by useing carby cleaner (I used kero and a compressor to dry and clear any blockages) also make sure that the spring moves(smooth) and the valve works.
Reassemble in reverse order with a bit of sensor safe silicon with the original gasket(or you could make another one it depends on weather the gasket comes off in one piece) hope this helps!
It really is quite easy!
The stuttering might be spark plugs, have them gaped to 0.8mm this helps (platinum/iridium plugs also are a good choice for turbocharged engines)
MEGA
P.s other than that it could also be dirty/malfuctioning air flow meter!
https://www.sau.com.au/forums/topic/5514-idle/#findComment-83958
If that dosen't help try cleaning/replacing the Air Flow Meter!
(these are very benefical for a good idle)
Many AFMs are dirty because faulty filter pods or ones that require oil on the filter and the oil/dirt ends up covering the wire and affects its ability to register air flow.
MEGA
https://www.sau.com.au/forums/topic/5514-idle/#findComment-84111
Guest VdubGuru
Thanks MEGA,
I cleaned out the AAC and also replaced the plugs. If you hadnt said anything about it i would have never have known to clean it out. I would have ended up wasting my time and money taking it to some shop who would have screwed me. If you are ever up here in Japan or you need something from here that you cant get there, just let me know. Thanks again.
https://www.sau.com.au/forums/topic/5514-idle/#findComment-84249
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
