  • Replies 59
Worse than the stock plenum? you joking right....?
I have had this talk with 2 workshops already, the greddy plenum isnt really need unless ur chasing high hp numbers (400rwhp+) but like croat said im getting it main to reduce piping and the time it takes to do another jobs
also, like u said to me once Sk, that the gtr plenum flows better than the greddy plenum is tottal Bs.
2 set-ups (both the same trubo etc) one running a greddy plenum (rb25) and one running stock gtr plenum (gtr) and the rb25 made more power on dyno and it also had a much better curve
just my 2cents
i have an issue of zoom with the 8th sin supra on da front and they proove on dyno figure the rb20 plenum out does the gt r plenum doesnt make sense to me sorta confusing actually
but i can scan the dyno if ya doubt
Quote "at serious boost levels 1.2 bar the stock manifold made power then the gt-r manifold.this goes against everything we have ever found and most of what has ever been written"
:werd:
hi this might help some of u's, the nissan infinity throttle body fits straight up to the GReddy plennum. these throttle bodies are 80mm id and can be baught second hand for $450-$550 from jap wreckers. a new one from nissan will cost about $1500. i've got a GReddy plennum and who ever tells you a stock one is better is playing with it. The only problem with the plennum is that it makes it hard to get to the oil filter from the top of your car. i have a oil cooler and remote filter which makes life allot easier. servicing your car on a hoist is no problem though. you's wont regret buying a plennum, good luck men.
guys, the plenum isn't for a power increase!!!!!!!!! don't confuse yourselfs, from what i have read up on the plenum, it's is for better and apparently more even airflow through the plenum compared to the stock plenum.......
adrian :)
true, but zoom probably did the comparo on a stock car where a plennum upgrade would make bugger all differance. i'd like to see the differance between the two on a flow bench. A more even flow = cheap reliable power. like any thing else, if it's on it's own the results are much less noticable. you get bugger all out of an exhaust mod, but combined with other mods it makes a differance.
you are correct about the sub zero plennum. the thing to be carefull of is fabricated plennums are usually constructed from sheet metals which are a hell of a lot thinner than a cast item such as the GReddy plennum. i,ve seen quite a few fabricated plennums and they all have been good (work well and look the part) but a few of them cracked, due to heat, pressure or because the welding process. (welding can make the materials britle hence cracked welds or beside the welds)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
