no, i was so up for the qld dyno day but it got cancelled.
maybe one of u guys can point me at a good place to go when i get to melbourne if I havent done it by then.
I was thinking if i could track down the manufacturer, the sticker on the model/serial on inside sticker may show what they did.. if not the serial number may.
Just trying to work out a few things on the car, and knowing what this is will help.
https://www.sau.com.au/forums/topic/5566-remapped-r33-ecu/#findComment-84388
