ok, i just installed my new FMIC. 300x600x76. Anyway, the piping is too fat and my fan is gonna rub on the pipe if i turn it on, and i dont want that.
My question, does anyone know where i can get a smaller fan, or if its at all bad to just clip the wings of it a tiny bit? Ive been told its bad to have uneven fan blades, so precision is vital.
If anyone has any info or help, would be greatly appreciated.
thanks.
https://www.sau.com.au/forums/topic/55989-need-smaller-fan/
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
