ok pplz, i noticed the other day when i got up my car a bit and took it to 7 grand it hit rev limiter in second before changing into third, and when i slowed down to a stop to turn into a street the car stalled? was this a result of the rev litmiter telling the computer to shut down so not to damage the engine or something else??? any ideas??? has this happened to any1 else, and also on idle sometimes it revs between 650rpm and 900rpm but goes up and down and fells like its going to stall?? thanx
https://www.sau.com.au/forums/topic/56234-rev-limiter-on-r33-gtst/
nah not caused by the rev limit, rb25s love running there :D
I've really needed someone to answer this question too.
Everytime I take it past around 6,000rpm I feel really guilty and bad for my poor baby :P
Are RB25DET's really rev happy? Like Honda VTEEKKKK BROOOO motors?
Try your throttle body.. Sometimes they become clogged and need to be cleaned out.
My car was acting like a spastic and revving like a retard and stalling so they cleaned the throttle body out and it came all good! Could be something as easy as that and a coincidence that it happened when you revved it out
definetly not related to the rev limit..
probably electrical related, such as AFM(i would try cleaning this before trying other things), spark plugs, or maybe a timing problem. also look for air leaks, check all the hoses.
well ive read another forum post in here and it opened up a can of worms! there are so many things to try and fix huh, afm, idle sensor etc etc. im convinced now that alot of skylines have this problem stocl or modded. they stall and play up on idle and deceleration sometimes. its all trial and error i suppose by the looks of it. it hasnt played up much only that once and i got a bit worried that i thrashed it too hard and it did something bad to it, but obviously not, by reading in here about it. so ive figured that step 1 :check and clean all meters and contacts and check hoses for cracks. thats a start i suppose. but i dont think my particular car has anything wrong with it, just that 1 time like it states in other posts, the fuel pump earth could be the problem. anyway thanx for the info pplz. i dunno what id do without this forum! good job guys keep em coming. 85URK
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
