Hey everyone!
Guest NismoWithNos
Hey Tasmanians... About that Yellow skyline... If that is the one that hangs out around Launceston it isn't actually a GTR.. it is all rice .... very rice lol...
And Also... I got some proposals for my car.. I messed with the picture for a couple of minutes.. although as dodgy as the picture is, u can see it has potential haha....
Should be "lowering" the car this week..
Steve
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-88746
You guys are really pathetic... maybe try reading the Message first... I SAID it was a dodgy job.. I couldn't be bothered spending much time editing the picture. It took me about 3 minutes... AND i was not bagging out the R33.. I was stating an ACTUAL FACT that if that is the car that hangs out around Launceston.. then it is not a GTR it has GTR Badges and that is all.. it is a GTS-T....
No, This r30 is not my dream car, simply a fun project car. I would rather a 300zx but I don't have the amount of money I would like to spend on one yet....
Next time read the text..... Don't go blowing your horns and getting ahead yourself.. for stuff sake lol...
Steve
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-89520
Steve
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-89525
Guest BoatsRbttr
:shake:
Hi guys I am a new member having a look around.
Read through this stuff and I would like to mention that I have seen that yellow skyline, I don't think RICE is the word here Steve, I pulled up next to this thing in town the other week, hearing what sounded like a touring car, I looked at the front of his car noticed Water pissing out of it, only because this pretty sick Under car lighting kit thing was highlighting the ground like all hell, so i said mate you might have a problem there, he shook his head and said "the only problem with this car is keeping it straight!!" and he put the thing absoluetely sideways around the corner and snapped third i think, burning tires like no tommorrow, it was poetry in motion. Don't know muck about this Rice stuff but i understand it is a bit of an insult so i reakon their right to think your a bit of a tool. Any way I still think boats are better! ;)
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-89637
OK.. let's clear up some things... I never said I didn't like the car.. It is nice and all.. I didn't think me calling the Badges rice would be so offensive to you all.... I was told that the car was a GTS-T not a GTR, therefor I called the Badges Rice.... It is a nice car but I was simply stating that that car is not a GTR... And if your car is a GTR, then I must have the wrong Car....
Intercooler sprays are cool and neon lights are good too....
No offense intended aye...
So is yours a GTR or not? I saw another Gunmetal R33 GTR in town today... Love em...
Later
https://www.sau.com.au/forums/topic/5695-hey-everyone/#findComment-90029
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
