I believe that its only fair to worn fellow members of savings that could go towards debts or repairs etc, instead of throwing around $200-$300 on nothing. And as for getting ripped off, I believe this thread has shown myself and other members buying brand new, full warranty, mobile phones delivered to door from super safe ebay powersellers with 100% rating.
So what your saying I am an idiot for speaking the truth to fellow members?
So what would I be if i decided to keep this from being heard, and letting people throw money around when they shouldnt have to.. saving people hundreds?
So what your saying I am an idiot for speaking the truth to fellow members? and saving them hundreds of dollars...
ok girls no point arguing on who's telling truth or stating opinion on the forum... this is now officialy became off topic.
General public (SAUER) aint stupid enough to buy $1 mobile or $10G for 2000 R33 GTR.
Come on That's why we have PM - its stands for Private Message,
you ask question if a product is fishiee(so speak) if found to be it is notify US(Mods)
but I dotn see point Broadcasting 'here is better priced product on the thread where someone trying to sell a product. I dont see you buying any phones...
my two cents.
Glueie
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
