Hey just wondering if any1 had heard of MB Quart speakers and whether or not they are any good? Just put a deposit on some DSE-216 6 1/2 splits without really thinking about it!!! I usually restrict myself to the more well know makes and have kinda stepped out of the circle on this one! Any feedback will b much appreciated!!! Happy lining!! (i mean SKY-lining!!!)
https://www.sau.com.au/forums/topic/57504-mb-quart/
Did you listen to them?
If you liked em then you should be happy regardless.
A few years ago they really were a real presence on the market but they seemed to be overwhelmed once the focal hype hit the streets. They are a good speaker though, I am not familiar with the models anymore.
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109031
I go the 5 1/4 inch discus series in my car, and MY GOD! I love them hey, I want to hug them every nite almost, they are so damn clear!
I really need the 6 1/2s for the music I listen to, so enjoy them. (ps, wanta swap for the smaller speaker :rant: )
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109109
hahaha yeah i'll swap em for a frount mount!!!! sweet...i'm stoked that someone is happy with em!!! got the 6 1/2 components for 329 from a place called stylin audio in melbourne.....went there to buy an immobiliser and thats all....i took only money for the immobiliser coz i knew if i took my cards i would end up buying stuff that i can't really afford!!! immobilizer ended up being 50 bucks less than i thought so i put 50 deposit on the quarts.......always happens!!!
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109124
What range are they? When I got mine they had the top of the line 6 1/2s for cost price ($500 or something) if I had the extra $300 I would have got them. Id say thats a good buy. (espcially when my mate got a quote for $700 for some alpine things). Just the one tip Id have. Mount the tweeters lower rather than higher, I find them a little harsh at times.
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109138
Yeah I'm gonna get them to install em...pretty much can't be stuffed, and they installed my immobilizer.........oh yeah thats what i was writing........just had a massive blue with my ex over money she owes me anyway.........yeah they did a great job with the immobilizer so il get em to do the speakers too
range??? im not sure, i was going to get the tweets mounted on the a-piller but i actually also just read that thats probably not a good idea so awesome thanks for the advice il get em mounted down low....what r u running in the rear daveo?
https://www.sau.com.au/forums/topic/57504-mb-quart/#findComment-1109236
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
    • Do this, and we'll have a resource right here.
    • "Hybrid" is a meaningless term. I could not tell you what the vendor of that turbo means by "hybrid".
