  • Replies 105
Originally posted by UR2EZ
tactic goes to free his juices (pee) from his beef (willy) kebab but finds out he has a tuna (pu$$$$y)  kebab instead
Fook dish sh*t
Man, next cruise if i drop my wallet im kicking it to the car!! :uh-huh:
buncha homos!
Beta yet, me and Rhy just gonna mow all you k*nts down,
hahahahah
FFS get a ROOM! :(
Donnie :D
We are the worst man :(
eehehe
I betcha george is crouched in the corner of his dark room crying
"but all i wanted was a kebab"
ahahha
we have officially hi jacked his thread with another one of our gay facination discussions :)
hehehehe
DOnnie
O btw those things minh said about me are not true until proven in a court of law :D
I had a fight there and I dont think they will allow me back.
Well maybe.
Yes its yummy as.
****en homos. I was eating with my friends and skinny little ***** gangster wannbe long hair fags started to stare my friend out. So I walk over and cracked him one right on the jaw and he just dropped and slumped in his chair. Big fight broke out after.
We got the upper hand and then the owner got the upper upper hand and told use t leave.
Their icecream are very nice.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
