well no more money for beers tonight
two pints in city then pete the poof shoots through. soft mate
mmm enter a mate, my living room, a fresh case of vb, a 6pack of extra dry already in the fridge, and a 6 pack of woodstock (nasty)
my poor rectum
shat beer for 30 minutes this morning
nasty
once again, thats dirty man.
btw. i have not started my beer appreciation yet. i tried one girls beer (stella) and was having trouble at the end of it.
i needed a shot of bourbon to wash it down with but was going to be late for work.
mate i still don't like beer
but i do at the same time. it's good. mmm BUT since starting drinking it on my canada trip in july i have gonme from about 95 to 103kg. nasty.
beer = good if you do some exercise with it hehe
stella is girls beer :bs!: wtf. gtfoh no way its a girls beer. its top shelf beer ie. premium beer. becks, san miguel ( pale pilsener atleast) and steinlager otoh.
( :throwup: )
:D:D:rant::);):D
try a crown lager, blue tongue, cascade premium lager or hahn premium lager. :) aussie's finest. oh james bosgs premium lager and james sqire ain't either. id don't like them that much personally.
Fark...
Tuesday night - cant remember after about 11pm but everone else has been regailing stories. Somehow managed to wake up in my own bed with the lady (cheers have gotta go out to her as she got me back to Leichhardt from Newtown)
Wednesday - The lady's work xmas party till about 10pm in Artamon, then the Sando's xmas party till 12am, then a mates 27th in the Townie till about 3:30am.
Tonight - Sando as usual due to the fact its pay day. Probably kick us out at 2am then to the Townie till sun up.
Xmas eve - Getting shyted again at an indecided venue... Same again on xmas day & boxing day.
heh heh... my liver despises this time of year
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
